Oil life starts with a fixed number of revolutions and will decrease with each revolution
The oil life will drop to zero % after one year, regardless of the number of engine revolutions or how many miles since the reset.
They don't differentiate between idle RPM and 5000+ RPM ?
I've plotted the oil life in my wife's Fusion and while I've never went 10k miles on oil, it always trends towards ~12 months no matter the mileage. This is why some people see the % drop non-linearly if they watch it often enough. They adjust for "time" just as much (as GM says).
The Fusion OLM was at 1% when the oil reached 10k (M1 AP) in 9 months.They don't differentiate between idle RPM and 5000+ RPM ?
Well, they do, just not directly. If you count revolutions, you'll get half the number of combustion events (4 stoke engine). At idle, you'll be counting revolutions at idle speed, say 700 per minute. At 5,000 RPM, you'll count 5,000 per minute. So it decreases oil life much faster at higher RPM than it does at low RPM.
There are also multipliers for hot and cold operations as well, so you can "magnify" the impact of hot or cold operation on the number of cycles it counts.
I have two GM cars with this system. I drive one a lot on the highway and one is parked a lot (2020 is a mess). The one that is parked is hitting the age limit for sure. The one on the highway is combustion events. I drove the one that sits a lot to Florida last year and my oil life moved 2% the whole way down, then was moving a little more than 1% per 1,000 miles on the way back. My guess is that they run both of the algorithms (combustion events and time) in the background and then display the lower of the two. I that case on my car, they crossed over halfway through my trip.
I would guess it is based on whatever meets min spec in the manual. If an oil was that exceeded that spec, it might be usable for longer. Maybe. Then again, just what is exceeded, and if that is the critical spec, is an unknown. Fuel dilution might be an example of not being able to exceed x miles / rev's / gallons of gasoline even with a better oil.Does the OLM assume a worst case scenario such as the cheapest (production wise) conventional oil or is it designed around the OEM fill?
What makes you think they're not the same ?Does the OLM assume a worst case scenario such as the cheapest (production wise) conventional oil or is it designed around the OEM fill?
I believe Honda has a contingency plan for these scenarios so that customers don't have to return in 1000 miles for a tire rotation, etc, etc. Was just reading this in the past week or two.As far as coordinating the OLM with other required service, Forget it. This is an oil monitor, not a tire monitor or anything else.
If the vehicle specs conventional, the OLM will be based on that (for 'safety' reasons). If it specs synthetic, the OLM will be based on that. If a customer chooses to use synthetic, they just have an add'l safety buffer.
