The reason I put this in the Engine Oil Filter thread is that GM has specified higher bypass valve pressure differential settings due to this new innovation. I have attached the TSB from 2017 describing it.
I have seen mentions of lower than expected oil pressure from these later GM V8s. Also total loss of indicated oil pressure due to a code that sets for low oil pressure. This problem is apparently fixed by replacing the filter.
Anybody know if this setup is still being used? The TSB covers 2012-2017, has it continued thru 2020 into 2021?
I have a 2020 6.0L V8 that will not build up oil pressure by just cranking. The engine has to be running, and it takes a couple of seconds for pressure to show on the gauge. When I do an oil/filter change, I prime the engine by cranking 10 seconds in flood clear mode. Should be enough to get all the air out. I usually see the gauge start to get pressure around the 10 sec. mark. But with this engine I'm not seeing that. FWIW, this engine came from the factory with a PF-48, with the lower bypass pressure.
Any thoughts?
Edit: Be sure to read the TSB.
Any thoughts?
