GM dexos™ ?
Originally Posted By: steve20
the poster who said dexos1 oils must be at least semisynthetic to meet the dexos1 spec--is that an accepted/accurate statement?
I think it's becoming an accepted statement, because nobody has yet released a conventional oil that meets dexos. Since the AC-Delco dexos approved oil is a syn blend, I think that sort of demonstrates the minimum formulation required to meet the spec. (But I don't doubt that Castrol will try to undercut it!)
Any brand name api SN Full Synthetic oil should exceed dexos1
Esp if you look for something with additional specs on it.. ala Mobil 1 5w30
not saying o'riellys or supertech would... it might or might not.
Originally Posted By: FastGame
I know the GM dexos™ approved oils are 5w30 because GM doesn't do things like 5W-20. Would the 5W-20 SN oils from the approved companies still meet GM dexos™ spec's other than viscosity ? Would something like Mobil 1 5W-20 SN still have the extra cleaning, wear protection, and other things that are covered in the dexos spec's or would it just contain the add pack that meets API SN ?
Thanks
Why not just use the 5-30 that it calls for?? not sure why you would care what 5-20 would do
I posted this also.
I don't have anything GM so not looking to substitute an oil V , I have Ford and Dodge and they call for 5W-20. I just want to know if xW-20 SN oils are as good as 5w30 dexos, dexos does go beyond SN spec.
I wanted to know if 5W-20 still had the same ingredients as the 5w30 to meet dexos and this wasn't just a viscosity thing.
Not necessarily true in all cases. dexos1 has more stringent performance requirements than SN.
I haven't either, seen any OTC Syn/Blend oils that meet Dexos 1(a syn/blend itself), only OTC full Synthetics that meet this spec.
And I am only now seeing this spec on the bottle label as I had just recently(~a month or so ago/and posted here)looked at many of the bottles on the shelf at W*M & AAP and couldn't find any oils including full Synthetics that stated this spec(Dexos 1) on their label.
If any members here remember my post at that time, I was with my buddy(who had just purchaced a new '11 Equinox) and he couldn't find the Dexos 1 on the labels either. In my post here @ Bob's, I had asked if, "we should be looking on the bottle label for a...GM #(representing Dexos 1) or the wording Dexos 1?"
Although the new SN/GF-5 oils are on the shelves and this is what we were looking at, we still didn't see that spec.
Just the other day while shopping, I spotted it @AAP and I wasn't even looking for the Dexos 1 spec
