ekpolk
Member # 3733 posted December 13, 2005 03:54 AM
"The 3.8L is one of the longest-lived engine designs ever. It has, during it's GM tenure, appeared mostly as a 3.8L (231 cid), but has been made in both the 3.3 and 3.0 shorter-stroke versions. During the late 60s, early 70s, GM had actually sold the tooling to Jeep/AMC (I think it was them...), but later bought it back. It first appeared in production as a V-6, 198 cid version in 1961, 44 years ago (easy for me, since I first appeared in 1961!). But the supreme irony of this engine is that it was developed from, of all things, an experimental all-aluminum V-8 that GM was toying with during the 1950s, hence the 90 deg design. To get to market with a V-6 fast, they chopped this engine, made it from the easier iron, and the rest is history. As a result of the 90 deg bank angle, it suffered through being a Harley-like uneven firing interval engine for several years until they fitted it with a split crank pin crankshaft. Turned out to be a pretty good engine, but you'd hope it was good with 40+ years of development. "
Kaiser Willys bought the rights to the engine and the 225 "Odd Fire" V6 appeared in 1966 CJ5's and C101's. AMC sold the rights back to Buick in 1974. People hate the idle, but I love it and you can crank the engine down to 400 RPM for rock crawling. The flywheel also weighs about 80 lbs!
Great inertia.
