Originally Posted by metroplex
I think the rings are shot because the oil is just really really black in a short period of time. She can't afford any serious expenses on the engine (like new rings/pistons/etc...)
I still need to change her spark plugs, apparently GM wants these changed every 60k miles even though the AC Delcos (rebranded NGK fine wire iridium with platinum on ground electrode) plugs are rated for 100k on other applications including GM's own LNF GTDI. I have the spark plugs on hand, but just need a day to change them and maybe throw in a borescope to check the cylinders.
I was about to retrofit the Mishimoto Camaro oil separator system, but then I thought, she is probably not going to drain those containers periodically... and the engine will just suck in a gulp of vapor/water/oil mixture and hydrolock the engine. Scratch that. I think for the time being I'll just keep pouring synthetic 5W-30 in there until the next oil change, and then have her check the oil level every 1,000 miles.
The engine idles like silk, sounds great, holds boost and produces lots of power, gets great mileage (22-23 mpg in city driving, 25 mpg mixed, and 30 mpg freeway), and I can't see any visible signs of smoke or smell anything odd. This is what makes me wonder if it truly is worn out rings or cracked/damaged pistons. The engine is almost at 98k miles.
If it is burning oil , first check the PCV system . If that is OK , then do both a wet and a dry compression test .
