I've gotta pull the shafts from a '13 10bolt in an Express AWD.
The ABS tone ring (which I believe was only used for two years) seems to just kinda "press" on to the shaft with a rubber ID. I gently pried the shaft out and now the interior rubber appears a bit torn up.
I wasn't sure what else to do as the tone ring lives inboard of the wheel seal and wheel bearing, so I think it has to come apart this way? Is it acceptable to just reinsert the shaft and push it in? Again, not sure how you'd do it any other way but maybe I'm overlooking something
Ultimately the tone ring just has to "hug" the shaft enough to rotate with it I guess
@GMBoy @clinebarger
@GMBoy @clinebarger
