My kid plays around a lot with the visor, and occasionally puts some weight into it. So one day it just falls off right at the L. Looks like it's all plastic and the break looks really porous. I popped off the cover and it was easy enough to remove (unscrew) the mount from the headliner to work with it.
I decided to use what I have, which is Loctite Quickset Epoxy in a dual-tube syringe. It's always been kind of tricky because it never seems to actually set in 5 minutes like it claims, and varies a lot depending on the ambient temperature. I've usually preferred to put it on both surfaces, let it set a bit, and then put it together when it's slightly hardened. This piece is really tricky because there wasn't really any kind of good way to keep the pieces together except by hand. And it's tough trying to keep it together for 20-25 minutes. It slipped a few times and separated, but I was still able to put it back together and now it looks like it's set although not fully hardened.
Any idea if this is going to work? I've made mistakes by trying to see if it might hold the next day, but I hear that maybe a full 24 hours would be ideal. I'm also not sure if there will be an issue with UV. I don't think this spot gets a lot of light, but maybe a little bit.
