Getting rid of "This Connection is Untrusted"
los angeles
I've downloaded FF and almost always i get the---"This Connection is Untrusted
You have asked Firefox to connect securely to www.yahoo.com, but we can't confirm that your connection is secure.
Normally, when you try to connect securely, sites will present trusted identification to prove that you are going to the right place. However, this site's identity can't be verified.
What Should I Do?
If you usually connect to this site without problems, this error could mean that someone is trying to impersonate the site, and you shouldn't continue." HOW do i turn this annoyance off? Even for Ebay I get this.
The date on your computer is probably wrong. Once you fix that I bet all the sites will start working for you properly.
Make sure the time zone is correct on your PC AND your router if your using one
