Hey all,
I just got my Blackstone Used Oil analysis: http://imgur.com/kWtd0.png
This was on a ~52K 9-2X Aero (rebadged 2005 Subaru WRX with some blush and lipstick) with 3334 miles on German Castrol and a Wix 51365 oil filter. This is the first oil change with German Castrol. The previous owner used Mobil 1 religiously.
As you can see, the copper and silicone are a tad high. Blackstone said that the high silicone can be caused by dirt getting past the air filter so I'll check that. I'm using a Subaru-made aftermarket intake which was bought used but appeared almost new (the filter literally looked brand spanking new).
The copper is supposedly due to wear of copper parts. OK, but what copper parts are there in these engines?
Some searching seemed to imply that GC UOA typically has *slightly* elevated Si and Cu levels as these elements are part of the additives in the oil. I figured I should confirm with you guys here, however!
Any thoughts on my UOA in general? Thoughts on the Cu and Si in particular? Any insight is much appreciated.
Cheers,
DW
Cheers,
DW
