2019 Genesis G90 AWD 3.3T
Performed the intake valve cleaning procedure today using CRC GDI IVD Intake Valve & Turbo Cleaner. I used the STP Intake Valve Cleaner about 14k ago, my review is here. The CRC went in via the brake boost line on the manifold, the STP went in via the throttle body.
For the CRC, I followed the write-up here; very helpful video, thanks. The procedure is easy and takes about 15 minutes. I would recommend revving the motor to 2-3k RPM's while firing short bursts of the product into the manifold via the brake booster vacuum intake.
I let it sit for an hour per the instructions and then took it for a 45 minute drive in Sport Mode. The engine is noticeably smoother and quieter. Throttle response and acceleration are also improved.
Going forward, I will only use the brake boost intake method, it is quicker and easier. And, only after I used the STP via the throttle body did I notice a sensor downstream between the manifold. So, that sensor was soaked in cleaner; I didn't experience any issues, but probably not a good idea.
