Living here in Northern Minnesota, I would think the local stations would watch their winter blend of diesel, but apparently not. So I've had my rig (Jeep Grand Cherokee built in Austria with the 2.7L 5 cyl Mercedes diesel) inside an insulated attached garage for a week now after having it not start at -15 degrees. Garage temp is about +30 and I can heat it up beyond that. I seriously suspect a gelled fuel problem, despite the Power Service I also use. Will the garage heat fix my fuel problem, or is there so much wax in the filter that it just plain needs to be changed? I am planning to run straight #1 from here on out in the winter! Unfortunately the tank is full now.
So what about that filter?
