No, not at all. The 4.44 gearing nets faster acceleration is every gear. The effect of gears is to multiply toruqe, and in this case a 12% increase. That is in effect in every gear. Get through the gears faster, get to boost sooner, get through the rpm range sooner and get to the next gear quicker. All about 12% faster. An additional 30 Ft torque at the wheels through gearing is definitly noticable.
The issue is acceleration. From a start, getting up to highway speeds, I have to go through 3 maybe 4 gears. The acceleration can be had through gearing or through more power. Believe me, every time you have to accelerate in my car, you will accelerate with the all the force you can. The turbo whine, the air sucking soung, the thrust into your seat, it is very intoxicating.
So, it is not so much an issue of down shifting down shift when I am on the highway, is is for the actual acceleration within each gear as I am in each gear.
The down side, if there is one, is that when I am cruising on the highway at 70mph, I will be 400 or so rpm higher after I have enjoyed the acceleration.
I am going to put the pedal to the floor regardless. I can go faster through gearing or more power. The question is, If I choose gearing, is the resultant cruising at 400 rpm higher on the way to work harder harder then putting the pedal to the floor with yet more power per litre harder.
On one side, I will stress the engine more with more power with a bigger turbo and on the optother side the engine load actually decreases through gearing but the effect on bearings is unknown to me.
I would thing rings would give out before bearings but that is wht I am asking.
