Has this been discussed before?
If not:
What would happen if I added 1/4 - 1/2 qt (maybe 1qt if I'm in the experimenting mood) of 80W-90 gear oil to 4-5 qt of oil (say 10W-40).
I have a 1981 Ford 302 V8 that loves thick oils. If you use xW-30, the gas from the carb will promptly thin it out in no time causing it to flood the combustion chamber (weak rings? I installed new valve stem seals at 95k miles).
If you use 10W-40, it runs great.
Now I've been wondering - would the additives in gear oil work great in engine oil coupled with actual engine oil? Gear oil generally isn't cooled by anything other than ambient air temperatures. It doesn't get filtered and doesn't get changed for 100k miles. That's quite some abuse for all that metal to metal contact...
If not:
