Hi,
First time I'm posting this, so not sure if this is the correct way
Petrol Engine 4.2 Litres
This is an RB26 and I was using German Castrol 0w30.
The viscosity seems a little low?
The diagnosis said:
The engine never really sees over 90 degrees, but its more common to run 10w40 rather than 0w30.
Feedback appreciated.
Thanks,
Gareth
Code:
OIL MAKE - Metals (ppm) Aluminium (Al) 5 Copper (Cu) 8 Chromium (Cr) <1 Iron (Fe) 15 Lead (Pb) 5 Tin (Sn) 1 Nickel (Ni) 1 Contaminants and Additives (ppm) Silicon (Si) 11 Boron (B) 5 Sodium (Na) 7 Potassium (K) 1 Phosphorus (P) 945 Molybdenum (Mo) 7 Magnesium (Mg) 413 Calcium (Ca) 2164 Zinc (Zn) 1042 Physical Tests Water (%) <0.1 Nitration (Abs) 15.2 Viscosity (cSt,40°C) 63 PQ Index <10 Glycol (Abs) 0.6 Petrol (% by Distillation) 2.4
Quote:
All wear levels appear within acceptable limits for
first sample. Silicon level (dirt/sealant material)
satisfactory. Water content acceptable. Fuel
dilution satisfactory. Please check recorded
viscosity against requirements
