Patman
Staff member
Because of my recent starting and misfiring problems and I suspected possible fuel dilution, I changed the oil early on my 1995 Firebird Formula, and here are the results from Wearcheck Canada.
3000 miles on oil
March 13-May 16 (2 months)
102,000 miles on engine
German Castrol Syntec 0w30
K&N oil filter (oversized)
AC Delco air filter
Daily driven, lots of full throttle
5 Quarter mile runs
8 dyno runs (4 or 5 with no air filter)
5L oil capacity
1/4L of top up oil
Iron 16
Aluminum 4
Lead 3
Copper 1
Chromium 1
Tin 1
Nickel 0
Titanium 0
Silver 0
Vanadium 0
Silicon 10
Potassium 1
Sodium 12
Boron 2
Barium 0
Calcium 2910
Magnesium 134
Moly 3
Phosphorus 805
Zinc 911
Sulfur 2678
Manganese 92
Fuel 0.5%
Glycol 0
Water 0
Sulfation 45%
Nitration 44%
Oxidation 64%
Viscosity at 40C 70.3
Viscosity at 100C 12.3
VI 174
TBN 7.21 (D4739)
So I was quite shocked to see the fuel so low, especially considering the fact that fuel was yellow flagged on the Wearcheck website before I saw the final numbers here. Perhaps they retested it and found it was ok.
(although if they retest an oil for fuel, wouldn't some of it evaporate?)
I figured the wear numbers might've been a lot higher based on the problems I had on this run, although iron is still higher than it should be for a 3k run (my first 3k run with this oil only showed 8ppm of iron) but there was also some cold weather at the beginning of the interval too. And it's also possible that when I flooded my engine, a lot of fuel did get into the oil, causing the higher iron wear, but then since I drove more than another month, most of that extra fuel was burned/evaporated out of the oil.
The hard starting problem was due to a burnt coil wire, and a GM dealer fixed it. That same dealer caused my rubber tube to my throttle body to get even more ripped, and on the dyno we found the car to be running lean as a result. That intake elbow has since been replaced, so my next UOA should hopefully show a lot less silicon in it now that things are sealed up more tightly.
(PS-for those that didn't read my thread in the racing section, my dyno tuning session bumped me up from 254rwhp to 265, and bumped my midrange torque up by 30ft pounds!)
So those are my excuses for running a short 3k interval here.
Another big reason is because I want to have a "perfect interval" with this oil, that is with no cold weather, no mechanical issues and my nicely sealed up filtration system now. So I will run this oil until September or October, I'll wait until the overnight temps start going below 50F again. So I hope to have as much as 8k on the oil by then.
Yes, I'm still running GC 0w30 and a K&N oil filter. Let the good times roll.
edit, decided to clean up the format and round off the wear numbers to the nearest decimal point.
[ July 15, 2004, 10:38 AM: Message edited by: Patman ]
3000 miles on oil
AC Delco air filter
5 Quarter mile runs
5L oil capacity
1/4L of top up oil
Iron 16
Aluminum 4
Lead 3
Copper 1
Chromium 1
Tin 1
Nickel 0
Titanium 0
Silver 0
Vanadium 0
Silicon 10
Potassium 1
Sodium 12
Boron 2
Barium 0
Calcium 2910
Magnesium 134
Moly 3
Phosphorus 805
Zinc 911
Sulfur 2678
Manganese 92
Fuel 0.5%
Glycol 0
Water 0
Sulfation 45%
Nitration 44%
Oxidation 64%
VI 174
TBN 7.21 (D4739)
