I've used Redline in this engine since 3000 miles but decided to give GC a try. Total miles on the engine is 54,985. Miles on this sample is 5,089.
First number is the current sample and the next two are the previous Redline samples.
aluminum 2/2/2
chromium 1/1/1
iron 6/4/5
copper 4/6/4
lead 10/14/6
tin 0/2/1
moly 50/521/428
nickel 0/0/0
manganese 0/0/0
silver 0/0/0
titanium 0/0/0
potassium 0/0/2
boron 0/7/5
silicon 5/8/11
sodium 3/15/26
calcium 3273/3370/3433
magnesium 107/5/5
phosphorus 741/1107/1196
zinc 885/1308/1215
barium 0/1/0
sus viscosity @210F = 64.3
flashpoint = 380
fuel = antifreeze = 0
water = 0
insolubles = 0.3
TBN = 2.8
Blackstone's comments:
Lead, from the bearings, moderated a bit in this third sample, even though the oil was run a little longer, 5089 miles vs 4963 miles for the last sample. Lead really should read about half the iron wear level, making 3 ppm a normal reading in this sample for your Subaru engine. We found traces of gas in your oil and maybe that is making the difference in lower end wear. All the other metals read perfectly, even though your oil use run was about 250 miles longer than average, for this type engine. The TBN was 2.8 so active additive still remains in the oil.
[ February 02, 2005, 06:48 PM: Message edited by: harrydog ]
aluminum 2/2/2
chromium 1/1/1
iron 6/4/5
copper 4/6/4
lead 10/14/6
tin 0/2/1
moly 50/521/428
nickel 0/0/0
manganese 0/0/0
silver 0/0/0
titanium 0/0/0
potassium 0/0/2
boron 0/7/5
silicon 5/8/11
sodium 3/15/26
magnesium 107/5/5
zinc 885/1308/1215
barium 0/1/0
flashpoint = 380
water = 0
insolubles = 0.3
TBN = 2.8
