Generally speaking, yes.
1) Lower startup viscosity means lower mechanical power loss resulting in higher MPG and reduced startup wear.
2) Better resistance to oxidative thickening while in service which should result in some fuel economy gains.
The magnitude of the savings is a huge matter for debate and will depend upon how the engine is operated and the amount of use the oil remains in service.
