I have an old 625 B&S Craftsman 21" mower. This spring, one of the wheels pulled a little free of the deck and I repaired it with repair plates, screws, nuts and left over pool putty. Given that it is 8 or 9 years old and is used 10 months a year, it has worked hard but the engine runs great. I run stabil in the fuel at about 1 oz per 2+ gallons with an occasional dash of techron when the cars get their dose.
I have been facing the unavoidable death or complete overhaul of all the wheels and deck. I have replaced some as they broke, but they all now seem to wobble enough that the mow can seem uneven to the OCD eye. As a result, I jumped at a neighborhood garage sale mower with similar yet newer 675 with no priming and the easy start system. Most of the parts seem interchangeable with the current motor. The family just moved into the neighborhood and decided to use a lawn service, as the husband had only used the mower a few times in the last house and this lawn is much bigger. They supposedly ran it dry on a regular basis.
Condition of the mower: cosmetically quite new. under deck surface corrosion due to storing not so well cleaned in a humid Texas garage. Oil is pretty new looking (supposedly only ran about 3 times total since new). Air filter had minor grass in the pleats that has been cleaned out. Plug not excessively fouled. I poured in my usual gas formula and it ran unevenly for maybe 30 minutes and then died. I had on my noise cancelling headphones, so I could tell the sound output was uneven and seemed to be more low key/ low rpm than my regular mower noise. I swapped plugs and finished the lawn with my old mower with the new mower spark plug. The change in plug had no impact on the dead mower.
Fast forward to this weekend. This morning I pulled the carb and scrubbed out the dried up varnish with carb cleaner and used a paper clip and the carb cleaner spray tube to get all the small orifices clean. Upon reinstall and adding new fuel, I got it to start after a good number of pulls. It seems to run a bit faster, but with then start to hesitate and the run quality deteriorates until it can maintain running and dies from start to finish is about 40+ seconds. Even when running full bore, it seems to run rough, vibrating the handle...
The gas cap seemed like it wasn't the original so I swapped with my old mower which enabled me to get it started but won't let it stay running. What should I check next? This is the first carb that I have cleaned in about 15+ years and the first on a mower. My current one runs great, so I never had to do any serious maintenance outside of changing oil and running a little more fuel treatment if the running deteriorated at all...
The worst case scenario involves a quick motor swap and selling the remains on CL to someone willing to fix it or simply returning it to the original owners. He made the comment to let him know if it had trouble running, either due to long period in storage or it didn't run so well when he used it last...
