My vehicle does neither have a trailer hitch nor a number of other options but the fuse box has fuses for those features anyway. I'm a little con-fused.
We see now on a lot of the replacement BCMs or SJBs where there is a note that it is a "universal" replacement and to program accordingly. Same actually with some PCMs, multiple calibration codes will be taken care of with one part number. The technician just uploads the as-built data from OASIS when programming, or else downloads the infor from the previous module before removing.They could use the same fuse box part and just leave out fuses for options/features a car doesn't have. From a manufacturing standpoint though, I can understand why they don't do that though. A fuse box with every slot filled would be one part #, another with 1 fuse left out will be a different part #, another with a different single fuse left out would be a 3rd part #, and so on.
It was a play on words, hence the hyphen.Why would you be confused ?
do you think they put different fuse boxes in cars for different features?
I see watt you did there.If you think that I implied that then you made a groundless assumption.
You saw the potential.I see watt you did there.
Tapped the seat heater fuse on my camry for my fog lights. It only works with the ignition on, and cuts out when the starter is cranked. If I wanted I could have used the fogs as DRLs. Needless to say, I had no seat heater.
It's very likely that the wires for what options you do not have are already there but tucked away into the harness. Makes it easy for the dealer to install those items.
That's happened to me once. The car had the wiring for the rear fog lights from the factory. I only had to add a fog light switch, a relay, bulbs, and a fuse.It's very likely that the wires for what options you do not have are already there but tucked away into the harness. Makes it easy for the dealer to install those items.
