I'm trying to troubleshoot my furnace. All things point to a failed circuit board. Carrier natural gas furnace..about 9 years old.
Symptoms:
A. Furnace fan runs at all times. As soon as the power to the furnace is on, fan switches on. With thermostat "Fan" setting switched to "Auto", "On" or "Off" the result is the same. Fan runs.
B. Furnace circuit board is not flashing any trouble codes.
C. Heat cycles on and off as normal when it gets cold in the house and a call for heat is triggered at the thermostat. Burner ignites and works normally at all times when it should.
D. High limit switch is closed circuit (not failed indicating a tripping of the high limit switch).
E. High Limit switch recently replaced due to tripping from drywall dust and clogged filter during a recent basement renovation - 8 months ago.
F. High temperature ignitor recently cleaned with steel wool to correct recent trouble code. 8 months ago.
G. Thermostat fan circuits are not shorted. All are showing voltage at the circuit board when they should, and no voltage when they shouldn't.
Troubleshooting theory:
- Symptom A above indicates a failed high limit switch, but C, D and E rule this out.
- Absent a failed high limit switch, the fan switch (in old style furnaces) or the fan relay (on circuit board furnaces like this one) is suspect - be fused. Tapping on the fan relay did not correct the condition.
- I have 2 of these furnaces side by side. The malfunctioning furnace behaves exactly the same as the functioning unit behaves when the functioning unit's fan setting is set to "On"/"Always On". When power is disconnected to either unit, there is a 3 second delay, followed by an audible click that can be felt with the fingers on the fan relay on the circuit board, followed by the fan powering up. I do not believe therefore that the fan relay is defective. Relay on malfunctioning furnace circuit board clicks audibly exactly as on the functioning furnace. Relay appears to be fine.
Everything points to a bad circuit board, and that I can't just source a fan relay for replacement on the circuit board by desoldering/resoldering. Am I on the right track here?
Next Steps:
The obvious way to prove a bad circuit board is to move the board from the good furnace to the bad furnace and see if that solves the problem. I'd like to avoid that if I can because there are at least 20 wires connected to each and this could be rather time-consuming and could potentially leave me with no working furnaces.
If I think I'm on the right track here in diagnosing a bad circuit board, I have a chance at a $100 circuit board that I'll just order.
Has anybody got any thoughts?
Symptoms:
Next Steps:
