Originally Posted By: JohnnyJohnson
A lazy mans accident waiting to happen. There will never be one of these on any of my cars.
Really? Sorry, but that just sounds like a lazy answer! Honestly. Work smarter. Hot harder. No endeavor succeeds by doing things the same old hard way, but instead by implementing time and labor saving methods. You wouldn't make it 6 months where I work. We don't stay on top of our industry by doing things the same old hard way, because that's just the way it's already been done.
Originally Posted By: gathermewool
Can we get a picture of the OP's setup? It seems very hard to believe that:
1. He was driving in the conditions he was (tall grass broke the safety clip AND opened the valve???) or
2. We're not being told something very important - such as the fact that the valve is in a very bad position, making it an imprudent choice for this application
I've had them on several cars over the past 7+ years and never had a problem. I can change the oil in my Forester without having to jack it up: slide pan under --> reach in and open the valve --> unscrew the top-mounted oil filter and clean the area --> install new filter --> hang out for a bit, until the oil stops dripping (it does take a decent bit longer than normal) --> shut valve --> fill'er up and I'm done. Zero mess (I wipe the valve and get less oil on it than I'd get checking the dipstick.
What does this save me? Well, I live in a condo. It saves me from having to go to the auto hobby shop on base, with invariably doesn't have a lift working or available. I've had to wait an hour to change my own oil. With the Fumoto valve, I'm in and out so quickly, I don't even worry about my condo mates ratting me out to the board for doing maintenance in the lot.
Spot on.
My mind immediately starts trying to do a root cause analysis on this. I'm trying to understand how something on the road would first snag and remove the safety clip that the OP says was installed. Second, snag the valve lever well enough to overcome the spring and lift the lever out of the notch, but not pull on it too much so as to break away when reaching the end of the 4 mm of travel. And third, at the same time rotate the valve lever 90°. Oh. And it has to do all this while the vehicle is in motion, but without pulling hard enough that the driver would be aware of severely snagging his car on underbrush.
We absolutely don't have all the facts here.
