Hey guys,
Got A new fuel tank, pump and sender (both Delphi) installed last Wednesday. Got it back with a little less than a quarter tank, drove around and ran a bunch of errands on Thursday. Ran great. It had about an eighth of a tank in it when I headed back home so I stopped and filled it up.
Got home and discovered a slow drip under the right rear corner of the tank. Determined it was coming from the sender or the pump. Stuck some clear tubing down the filler tube and siphoned most of the gas out, down to about 1/8 of a tank, which stopped the drip, and just left the car untouched until this morning.
Attempted to crank it this morning and it will not start. Cycled the key multiple times, can hear the pump run, but it won't fire. Added some gas where it now shows a quarter of a tank. Still will not fire.
The ECU has a stored code 21 "oxygen sensor." Don't know how long the code's been there, but I replaced the oxygen sensor a few weeks ago. It may not like the new one, but that's not causing a non-start. Cleared the code.
Pulled a spark plug and cranked it over, she's got spark.
When I pulled the pressure hose off the end of the fuel rail a few weeks ago to replace the hose, there was lots of built up pressure and a decent amount of fuel was released.
I just pulled the same hose today, nothing came out. There's not even fuel resting in the end of the hose. Gauge is registering a quarter of a tank of fuel. Should be more than enough to submerge the sock on the pump. No fuel came out of the hose when cycling the ignition, or cranking.
Pulled the ASD relay and powered it with 12 volts, the relay clicks and has continuity. ASD circuit tests at 12.1 volts with the ignition on.
Bad fuel pump?
Bad fuel pump?
