Fuel safe sealant
SF bay area, San leandro, Ca
IM looking for an RTV type sealant to replace a cork gasket that goes under the 8"x8" square bolt on fuel neck of a forklift I have.
ITS A relic that originally had a cork gasket in this connection but I really don't want to hassle making another cork gasket.
Years ago I used to use a product made by OMC ( Outboard Marine Corp ). They made a couple diff versions, the one I used that was fuel proof was called "type M", for metal to metal contact.
MOTOSEAL1 it is.
Forms a tough flexible bond that is highly effective on irregular and uneven joint surfaces. Ideal for use on frequently disassembled engines. Resists gasoline and other damaging fluids.
sounds exactly like what I have. Being a 30 year old machine close tolerances weren't their strong points.
This is more to keep the WATER out than the GAS in.
