Hello,
I have a question concerning being able to mix FP and Amsoil PI in the same tank of gas.
About four weeks ago I tried Fuel Power for the first time in my 1991 Ford F-150. I don't think it even took a 1/4 of a tank before the sound of the engine became noticeably smoother. Needless to say, this old truck now gets FP with every tankful.
This, however, causes me to have a problem. I need to figure out a use for the 3/4 of a gallon of Amsoil PI left in my closet.
One solution that seems very attractive to me is to combine a little bit of Fuel Power and a little bit of Amsoil PI in the same tank.
I know the abilities of the two will overlap and be redundant in many areas. However, I like the idea of mixing a good quality upper cylinder lubricant(primarily the Amsoil PI) with a good fuel system cleaner(primarily FP). On a side note, I know from doing searches on this forum that FP does not appear to contain a "true" UCL. Hence, my desire to add the Amsoil PI.
Any compatibility issues I need to worry about before I proceed with this experiment? What treat rates do you all think I should I use, the recommended rates on each bottle or slightly reduced ones cosidering the presence of the two products?
Any comments, thoughts, or warnings would be appreciated.
Thank,
bjohnson
Thank,
bjohnson
