Bad news. I have a 2004 Jeep Wrangler 4.0 six. It has the "in tank" filter and it's fuel filter part number is the same as a 2002 Dodge Grand Caravan. IMHO the "in tank" design is complete bull ****!
I wish the previous owners felt that way. I bought the car a month and a half ago with 184k on the odo.quote:
Originally posted by George7941:
If you feel the filter needs to be replaced every so often then there is no need to avoid the task.
I was worried to begin with but it's totally solid.quote:
Originally posted by Cutehumor:
I changed my 14 yr old 134k fuel filter when it got plugged. I used a flare nut wrench on the bottom line. I had no problem. But thermacotor, that's kinda dangerous with the possibility of leaking fuel.
You, and more importantly the person who buys the car after you, do not know that for certain. I'm certain that won't hold.quote:
I should try to post pictures of it. If I ever find the need to repair it, I'll just try to source a proper metric tube nut and reflare the existing tube. Until then I have kept and will keep a fire extinguisher in the carquote:
Take it to a decent independent shop and get a estimate. It may not be as bad as you think and the estimate is usually free.
