Quote:
I have the so called "sock type" filter in the tank of my 2001 Civic. You probably have the same type filter. After passing 250,000 miles some months ago, I decided to replace the filter and pump.(wasn't having any problems) After pulling the filter and pump from the tank, I can tell you don't worry about it. I felt after replacing it, it was unnecessary. The filter itself looks like an over size fine mesh screen. I think your pump will go long before the filter will get clogged. Trust me, I had 250K without the first problem. It's designed to last the life of the internal pump. When the pump dies, then replace it.
