quote:
Originally posted by lpcmidst128:
So some get better fuel economy by using thicker oil like 15W-40? It seems that a thicker oil will drop your gas mileage a bit. *-*-
That's the way it is on my 02 Jeep SE (2.5 4banger auto). If you drive it STRICTLY like an economy minded driver (nothing over 60 ..just ease the gas out of the lights and let the high stall converter bring the vehicle up to engine speed ..let the lock up work at the minimum speed ..etc.) you'll get 20-21 mpg on my suburban to work 44 mile per day drive. Use the a/c or be in a hurry JUST ONE LEG of the whole week and you'll be down 2-3 mpg. My daughter, if she drives it, can bring it down to big block range (12-13).quote:
I know that if I do just one jack rabbit launch, I'll screw up any attempt at even getting anything close to normal averge mileage for that one tank!
Agree. But it just doesn't have to be a different weight oil, the blend itself makes or breaks the performance. But YESS , I agree!!!quote:
Originally posted by Dr. T:
No, it's true. You can have increased fuel economy with a heavier weight oil. The CAFE chart can simply be used as a rule-of-thumb reference.
In other words, different brands can contribute as every oil has a different inherent coefficient of friction as well as the fact that different weights work better in different engines...eg. ring sealing contributing to increased engine compression.
