Originally Posted by Reddy45
Originally Posted by Tyson
Heard from the shop.....not the transmission!
Catastrophic failure in the rear differential. Pieces of gears everywhere.
None of it is salvageable, so getting a whole new rear axle/diff assembly for just under $2k.
I'll be hunting Friday!
I hope the trans wasn't damaged from trying to turn the jammed up rear end!
edit: Since I, and only I have serviced the rear diff, I find this troubling. Fluid was suctioned and filled every 50k. Supertech full synthetic 75-90.
Good news (relatively speaking)!
Hi Tyson
Sorry to read about the truck failure.
On a happier note, good luck from a Brit' Hunter for your coming season and may St Hubert be at your shoulder guiding you and keeping you safe.
Tikka.
Hi Tyson
Tikka.
