Originally Posted By: Diesel_Clatter
Originally Posted By: Saturn_Fan
Originally Posted By: kingrob
This was recently referenced in another thread. The Saturn line is now basically the American equivalent of the Opel brand. Apparently they're not selling well, or well enough to warrant the cost of keeping the line up and running.
Saturn has been dead to me (and most original Saturn owners) when they got away from their original concept of a completely independent car manufacturer that was distributed by GM. When they were absorbed back into the general line we all heard the death chimes.
+1 Kingrob. Saturn died to me a long time ago. Instead of taking a car like the S Series making it better (I get 40+ mpg in mine easily), they produced the ION. Instead of tweaking the Saturn VUE to make it better, they had constant problems with the CVT transmission, AWD system, body panels, suspension problems and constant noises, etc. I owned an 06 and it was a piece of [censored]. Saturn ceased being Saturn and became GM then Opel.
Sounds like your 2006 Vue experience is similar to my 2007 ION experience.
The ION has been solid for two years at the most basic level of not stranding me.
However, if:
Horrendous rubbery/squealing clutch pedal fixed under warranty, not uncommon complaint in forums
Instrument panel fit and finish, panel joints just absolutely horrible
Simple cabin air filter change turned into ordeal by bulging, misfitting dash plastic and dangling misplaced cables
Creaking and groaning driver seat
Cover on upper stop light popped off by child (whats this? pop
Little foam piece in rear door handwell pulled out by my autistic child and ends up in his mouth (what are you chewing on
Visible rust already at joint of rubber trim in trunk
Visible rust already at base of striker under hood
Multiple occasions of brake warning light staying on for no reason (yes, brake fluid level and emergency brake lever checked) until restart
Multiple occasions of ABS warning light staying on until restart
Fuel gauge dropping to zero for several days despite full tank
Occassional random warning chime at startup just to make me scratch my head
CEL caused by both switches on clutch pedal failing (maybe can credit this to dealer service of gripe #1)
Irritating buzz IP area of center dash
Front passenger seat cover clip coming loose in front, fixed by dealer, now loose again
squeak, squeak, squeak chirping bird noise to greet me when I drive with my windows down
nice groan from rear suspension when I back out from my driveway in the morning
are the definition of a piece of [censored], then, yes, sadly, I own a piece of [censored].
I read the fairly common refrain about how wonderful American cars are now and how we should just give them a chance with interest. Seems to me I have done this, paid full retail price, and now feel like quite the idiot for my choice.
To top it all off, the ION has slightly worse resale value than a bag of warm dog poo. I knew this going in but didn't give it proper credit since the plan was to drive it into the ground. Unfortunately, now that I realize this is like 15 years of purgatory, the low resale value leaves me feeling trapped as well as stupid.
Parked right next to my 2007 ION in our garage is a 2006 Corolla.
I have found that, unlike the ION, my initially low opinion of the Corolla has only improved over the years as we live with it. Toyota, seems to have a much, much, much better handle on the little details that can sway opinions.
When we buy our next car, do you think it will be a GM or a Toyota?
wow. do you have that all memorized, or do you keep the list on your desktop for quick cut-and-paste opportunities?
not to sound like a GM apologist, but my '04 VUE has been a great vehicle overall. just passed 60K, maintenance so far has been front brakes, sway bar links, struts and shocks. while under warranty, we had a water leak under the dash fixed, and a rear door that needed alignment, that's it.
the problem is, people tend to talk more about a bad experience than a good one. I'm not denying that you have all those issues w/ your ION, but it certainly doesn't represent the whole company.
I do agree, however, that saturn is not the same. but, I don't think the S series was all that great of a car. I've owned them and sold them and worked on them. horrible car to sell new. the test drive if anything would serve to make them NOT buy the car. not bad, just boring. and the engine, please. the ION's ecotec is light years ahead of the saturn 1.9 .
