I thought that the oil getting a bit darker was a sign that it was working correctly, that is getting the additives to work and suspending particles. Many of these particles are too small to be filtered out and for the most part, don't cause problems as they circulate thru the system.
OneEyeJack - are you saying that the particles that are too small to be trapped by the filter are what contributes to the oil getting darker ? Are those same particles dirt particles, or are they combustion byproduct particles ?
IMHO-combustion byproducts (soot/carbon), which should eventually stick together & be captured by the filter (or the oil pump screen if they get too big).
Yes, and yes and some additives get darker as well. A PCV system can contribute as well.
You should not let the oil get too dark if your car employees a chrome muffler bearing with digital framus matter seals on the isotonic pre-lubrication fittings.
If you use standard chrome muffler bearing you don't have to worry. Your OLM will be calibrated correctly. If you do have to replace those chrome muffler bearings here is a video to explain what you have to do. Even if you don't tackle the job yourself you will at least know what your mechanic is doing. Just make sure he is BFD certified.
If I have a dual exhaust system, do I need two of those?
ROD
Darkness like mentioned are a lot of factors one being carbon or soot, with bypass filter you can slow the process down a lot up until about 3k mile range. My oil in my truck stays clean almost like from the jug after that it slowly starts to darken to the 5-6k mark when I change it. But to answer your initial question no bud full flow like farm no matter what type of how expensive it is will not slow down the color change or get even close to filtering down to 2-3 micron.
The Microgreen and Trasko are the only ones I know of that can replace a full flow filter directly, and offer finer filtration. Car filter size. I don't know about the Trasko. I wish some others would have had experience with them and shared it.
Further down in this link they show exactly what is being talked about in this thread. They show clear oil after 5k on the bench test.
http://trasko-usa.com/about/about.htm
What are the filtration specs for the MicroGreen filter?
Per the Fram paper, it can't be any better than beta 75 (98.7%) at any micron level. Anything measured above that doesn't make sense and should be ignored.
