I was wondering if Fuel Power would be effective in neutralizing the corrosive effects of ethanol. Maybe Terry is lurking about and can answer this question.
I take it I could drop from premium to mid-grade in my truck that "requires premium fuel for best performance"? (Infiniti QX4)quote:
FP in both forms, "trick" the flame propogation into reacting as if they are octane boosters, at a certain level, allowing many gas engine users to drop a notch in octane levels of the host fuel.
I tend to think that this scenario is likely one of the best to take advantage of the lower AKI fuel in an engine that does not "require" 91AKI except to obtain best performance. Toyota, Nissan and I think Honda have been increasingly defining engines in this way. eg run 87 AKI by default but if you run 91AKI the computer will adjust timing to take advantage.quote:
Originally posted by Blake Sobiloff:
Woah! When Terry says
It'd only save me a buck or two each tank-full, but it might be worth trying to see if the mileage doesn't drop too much...
