Boy I tell you, the more horror stories I read about this subject, the more I'm even scared to drive my truck. Now, I listen to every little sound. Heck, most of the time I don't even drive with the radio on just so to listen to the engine. Lord, help me. My question and I really hope this ain't stupid, but the basic problem with barfing plugs, from what I'm gathering and researching, is the rates of metal expansion. Since the heads are aluminum and the spark plugs steel, the aluminum heads will expand quicker than steel spark plugs, right? Then that gives a little room for the spark plug to move until it reaches its' limit of expansion. That room, gives it enought space to "wiggle." Over time, that wiggle will become pronounced enough as to leaving the threads on the head looser and then the plug blows out. Do the steel inserts, not the helicoil, but the bigserts, really work? Can any cylinder plug be fixed by this method with out removing the heads??? OK, I guess letting the engine slowly warm up would be really beneficial in this case, agreed? Why doesn't Ford or other sparkplug manufacturers offer a aluminum spark plug? Will that not work since aluminum is a poor conductor of electricity? Another problem is over torque. If you over torque, the steel threads literally eat through the aluminum threads. Almost as bad as not tightening enough. Even Ford can't give you an exact torque numbers. It's something in the pounds/inches category. Anyway, thoughts???
[ January 14, 2004, 01:28 PM: Message edited by: Schmoe ]
