Ford yellow (VC-13G) replaces orange (VC-3B)
Santa Barbara, CA
SSM 48778 - Various Vehicles - Various Engines - Backward Compatibility/Use Of Motorcraft® Yellow Antifreeze/Coolant With/In Place Of Motorcraft® Orange Antifreeze/Coolant.
Various vehicles may require a cooling system service or cooling system repairs. Ford Engineering has approved the use of Motorcraft® Yellow Antifreeze/Coolant(Ford specifications WSS-M97B57-A1 and WSS-M97B57-A2) to service all Ford, Lincoln, and Mercury vehicles factory-filled with Motorcraft® Orange Antifreeze/Coolant (Ford specifications WSS-M97B44-D and WSS-M97B44-D2). For more service information on using Motorcraft® Yellow Antifreeze/Coolant with/in place of Motorcraft® Orange Antifreeze/Coolant, please visit the FCSD Chemicals and Lubricants U.S. Catalog at PTS > Workshop > MSDS > Quick Reference Charts > Service Information on Backward Compatibility/Use of Motorcraft® Yellow Antifreeze/Coolant with/inplace of Motorcraft® Orange Antifreeze/Coolant. The Workshop Manual is being updated to reflect usage of these antifreeze/coolants.
APPLICABLE VEHICLES
2013 - 2018 CAR: CG C344N C-MAX
2017 - 2019 TRUCK: E4 ECONOLINE
2018 - 2020 CAR: BQ B515S ECOSPORT
2018 - 2019 CAR: BX B515A ECOSPORT CHINA
2018 - 2020 CAR: R6 B515E ECOSPORT
2018 - 2020 CAR: BW B515A ECOSPORT INDIA
2018 - 2019 CAR: R1 B515E ECOSPORT RUSSIA
2018 - 2020 CAR: BY B515A ECOSPORT
2015 - 2019 CAR: DQ CD539N EDGE
2011 - 2014 TRUCK: Q1 U387/388N EDGE/MKX
2020 CAR: TC CX482N ESCAPE
2013 - 2019 TRUCK: M2 C520N ESCAPE
2011 - 2012 TRUCK: M7 ESCAPE/TRIBUTE/MARINER-LHD
2010 - 2017 TRUCK: B7 U222N EXPEDITION
2018 TRUCK: B8 U553N EXPEDITION
2011 TRUCK: U5 EXPLORER/MOUNTAINEER
2011 - 2017 TRUCK: UB U502N EXPLORER
2011 TRUCK: UK EXPLORER SPORT TRAC
2018 - 2019 TRUCK: UB U502N EXPLORER
2011 - 2014 TRUCK: F6 F150/LINCOLN MARK LT
2015 - 2019 TRUCK: FC P552N F-150
2011 - 2016 TRUCK: FA P473N SUPER DUTY
2017 - 2019 TRUCK: FE P558N SUPER DUTY
2016 - 2019 TRUCK: BC H567N MEDIUM TRUCK
2011 - 2013 CAR: B6 B CAR 4/5 DOOR CHINA
2011 - 2012 CAR: C4 B299A FIESTA INDIA
2013 - 2015 CAR: EG B299A FIESTA MCA CHINA
2012 - 2019 CAR: CN B299E FIESTA MCA
2014 - 2015 CAR: EH B299A FIESTA MCA INDIA
2014 - 2019 CAR: CT B299N FIESTA MCA
2013 - 2019 CAR: CM B299S FIESTA
2013 - 2018 CAR: C3 B299A FIESTA MCA
2011 - 2013 CAR: CH B299 B CAR (NA)
2011 - 2019 CAR: B9 B299A FIESTA TAIWAN
2011 - 2013 CAR: CL B299A FIESTA
2012 - 2019 TRUCK: P3 D471N FLEX
2012 - 2015 CAR: D2 C346A FOCUS CHINA
2014 - 2018 CAR: F1 C346A FOCUS MCA CHINA
2014 - 2018 CAR: EW C346E FOCUS MCA
2014 - 2018 CAR: F3 C346A FOCUS MCA THAILAND
2012 - 2018 CAR: DH C346N FOCUS
2014 - 2018 CAR: D7 C346S FOCUS
2012 - 2015 CAR: D3 C346A FOCUS THAILAND
2013 - 2020 CAR: C7 CD391N FUSION
2012 CAR: DE FUSION/MILAN/MKZ (ZEPHYR)
2018 - 2020 CAR: GX S922N GT
2015 - 2019 TRUCK: Y3 P131N STRIPPED CHASSIS
2011 - 2014 CAR: ZF S197N MUSTANG
2015 - 2020 CAR: ZG S550N MUSTANG
2019 TRUCK: FG P375N RANGER
2011 - 2019 CAR: PH D258N TAURUS
2018 - 2019 TRUCK: TH V363N TRANSIT
2010 - 2014 TRUCK: C7 V227 TRANSIT CONNECT
2015 - 2020 CAR: HC V408E TRANSIT CONNECT
2017 - 2020 CAR: PL D544N CONTINENTAL
2020 CAR: TF CX483N CORSAIR
2011 - 2016 CAR: LE D385N MKS
2018 - 2019 TRUCK: ME C489N MKC
2012 - 2019 TRUCK: P4 D472N MKT
2011 - 2015 TRUCK: Q1 U387/388N EDGE/MKX
2016 - 2018 CAR: D9 U540N MKX
2019 CAR: D9 U540N MKX
2013 - 2020 CAR: C9 CD533N MKZ
2010 - 2017 TRUCK: B5 U228N NAVIGATOR
2018 TRUCK: B9 U554N NAVIGATOR
2011 TRUCK: M7 ESCAPE/TRIBUTE/MARINER-LHD
2000 - 2002 CAR: ZN COUGAR
Ford vehicles themselves are forward compatible to any other make. Why strap yourself down with junk?
Ford Gold, Ford Orange, Ford Yellow. I am about to join the orator above in positing that Ford vehicles are forward compatible with nearly anything out there.
Gold and yellow are supposedly not compatible. I just wish they had chosen another color dye for the new stuff.
As for a proper flushing procedure, in another bulletin they said no flush was necessary. That being said I would use either the VC-1 or citric acid thing before changing over, but that is just me.
Being that Ford Orange is just Dex-cool I see no reason to switch unless you are in need of a flush in the first place. My cooling system at 115k miles appears very clean in the puke tank. It was flushed once at 80k and I do rad drain and fills every 2 years (was using the Ford orange but guess I'll be going with a valvoline dexcool).
I would suspect that the new yellow is Prestone with Cor-Guard due to the fact that it's a safe replacement for the old orange and Ford had a TSB about flushing the heater core in a Transit and refilling with Prestone instead of Motorcraft orange.
Just a theory at this point but maybe we will see something to back that up moving forward.
The Prestone with Cor-Guard uses phosphates (a good thing, IMO) and 2-EHA (not a good thing in some minds).
I wonder if PEAK's new 10X lifetime coolant uses phosphates?....I believe it does not use 2-EHA.
I wonder if Ford is moving away from 'Orange' (Dexcool) for a reason...or just to simplify things?
I replaced the 'Orange' in my 14' Focus with PGL....I'll probably do the same when my 2016 Escape is due.
Specialty Orange has a lot in common with Dexcool-it seems to eat & plug up everything it touches! The ‘18 Transit 250 3.7 in my sig has had a host of small coolant leaks, stealer could only fix the easy ones, didn't want to tackle the heater core. If Bar's Leak ginger root stop leak can keep it under control for a year, it'll be someone else's problem (lease is up June 2021)! Of course, I'll have another one then, but at least it'll have the new coolant in it.
I wouldn't say that Dexcool "seems to eat & plug up everything it touches"...….many cars run long, uneventful lives on Dexcool….often with no or infrequent
coolant changes. Dexcool does seem to cause problems in some vehicles but I would guess it's certain materials used in the particular vehicle (usually plastics)
rather than the Dexcool. Having said that....I would choose a non-2EHA coolant if given the choice....and I did just that by using Peak Global Lifetime when
it was time to change.....
Have a question. Does anyone know if Ford changed their orange coolant formula? I work for a fleet, we run about 4 different coolants. When I spec'd them, 2-eha always appeared in the MSDS sheets. When I looked and the Ford yellow sheet, it wasn't listed. So, I looked at the orange, and there was no listing there either. I know it used to be on the older orange MSDS.
To be honest, I have no idea. All I know is we can't get the orange anymore. When I try to order it to get some legacy stock for people who don't accept that things change, we get the new yellow coolant.
There is a problem with the coolant and block heaters ? Ford put out an OASIS about a year ago.
There is a recall on the block heaters. Ford doesn't put out an OASIS. OASIS is the system that stores all of the vehicle information which is connected to the PTS (Professional Technician Society) where all the workshop, wiring, and service info are.
Funny to see this posted. My 2014 Explorer is due for a coolant change and Ford Orange is definitely getting harder to find.
Is Dex Cool really the same as Ford Orange?
It's a one-for-one interchange.
And new Prestone which Ford called for on Transits after a heater core replacement is phosphated Dex-Cool more or less. It's an American twist on Japanese pHOAT, and while it does meet Toyota's requirement for a "coolant with hybrid organic acid protection" it's not an exact fit for the sebacate(or benzoate in Zerex Asian formula) inhibitors in Japanese fill.
I'm almost certain that Ford Orange is Dexcool because I saw the Ford spec. on a Dexcool jug....I just can't remember which brand it was. I would use Zerex Dexcool over Prestone Dexcool....for no particular reason...
thank you Me bad.
