I repaired the limit switches on a Chamberlain GDO for a customer and noticed that the plastic gears (worm) were dry and generating a lot of plastic shavings. The only grease I had with me was the XG3 which is a high temp silicone brake grease, somewhat thick. I applied the grease.
Figured applying the grease, even though thick, was better than letting the gears run dry.
