Ford Service Fill Approval
Kuwait
I've been looking at the Mobil 1 Product Guide, and specifically at the 0W-40 and 5W-30 ESP, because those are the only two products (plus 15W-50) on the list that are available locally. The 0W-40 has a Ford Service Fill Approval, but the 5W-30 ESP does not. I was looking at the HTHS viscosities of both, which are 3.5+ to meet specifications such as BMW LL. 5W-30 ESP is rated at 3.58, whilst 0W-40 is rated at 3.6. Despite being very similar, 0W-40 is FSF Approved and 5W-30 ESP is not. Neither oil is GF-4 approved, so that eliminates the possibility of FSF Approval being a WSS-M2C930-A certification. What exactly is FSF Approval, and would there be any issues with using 5W-30 ESP in a Ford engine, such as the Modular 4.6L? Thanks!
Illinois
I've used several M1 oils in my Merc., all went well. About the5-30 ESP call Mobil tech at 1=800-ask mobil. They can tell for sure.
Falcon_LS
Kuwait
Thanks! I've actually emailed their Global Operations, will be interesting to see what they say.
Texas
I find it soooo interesting that the recommendation for the Ford 4.6 in the states is 5W20 while what I suspect is the same engine calls for 0W40 or 5W30 overseas. Are the tolerences of the 4.6 sold outside the stated the same as those sold within the states? I would love to know if the 5W20 recommendation for the states is actually due to tolerences or simply to help achieve CAFE standards. I have a 3.9L V8 in a Thunderbird that naturally calls for 5W20 but the same engine in the Jag calls for 5W30.
WA
The 5W-30 ESP is made for Diesel engines. I bet Ford doesn't want a low SAP oil for their gas engines.
Falcon_LS
Kuwait
Ford recommends 10W-30 weight motor oil in the Middle East, although it's not uncommon to see people running 15W-40 or 20W-50 weight oils!
 Originally Posted By: roadrunner1
the 4.6 is imported by ford from germany
The Modular 4.6 is actually built in the US and Canada.
According to ExxonMobil, the low SAP "Helps to reduce poisoning of Gasoline Catalytic Converters".
Long Island, NY
I believe it's the 4.0l 'Cologne' V6 that's in the Explorer for many years.
