dnewton3
Staff member
There are some applications where this shorter filter would be a help.
Way back when, I bought a 1995 F-150 4x4 with the 5.8L (351) engine. I got all the heavy duty stuff, including upgraded cooling package. That option included a coolant-to-oil cooler adaptor sandwiched between the block and filter. The trucks without that package had no filter clearance issues, but those with the adaptor used the (then) "new" FL-820S because a longer fitler would simply not fit. And is was still a tight fit with the FL-820S!
Today, a shorter filter would help a bit more in that application, but it probably is a hinderance in others. The good thing is that there are so many good options from the aftermarket, that if you don't like one product, just move on to another.
