It also makes sense because engines want more intake valve area than exhaust.quote:
Originally posted by Jimbo:
As far as I can tell, it is two intakes and one exhaust for greater intake area within the same bore. This slightly odd three-valve setup makes some sense because they wanted to keep with the cheaper single cam setup and four valves would probably not package well in a single cam head.
3 valve heads give most of the valve area gain of a 4 valve head. Assuming my trig and geometry was correct and my simplifying assumptions reasonable...
A 3 valve head potentially give about a 30% valve area advantage over a 2 valve head.
A 4 valve head potentially gives about a 37% gain over a 2 valve head.
