Below is what was going on, the bogging is gone, the engine starts on the first try now. Sometimes when the idle comes down it will surge on the first start of the day, but that has gotten better too, it was doing it more often.
Now on a warmed up engine restart I get a surging the goes from about 400 rpms to just under 1000 rpms, and it will continue to do that until I touch the gas. I have gone thru everything. I had the issue below, and FI cleaning helped. Can these injectors still be dirty causing the warm engine restart surge? I had two mechanic buddies go thru it and they find no codes and no vacuum leaks. I read up on it on different Ford message boards and the surge is a common problem with hit or miss success in fixing it. I did a complete tune up and this thing runs strong has a nice idle when it isn't surging. Changing out TPS and IAC did nothing, MAP sensor did nothing, Coolant and ACT sensors did nothing. We even tried another ECM, same thing.
I installed the spacer plate below the IAC which did nothing.
As always thanks.
My 88 E-150 4.9L is giving me some problems. While crusing and slightly backing off the gas the engine feels like it is bogging down, as soon as you hit the gas the problem resolves itself, it is quiet annoying. There are no codes, I did a high pressure FI cleaning via the fuel rail with no luck, along with a bottle of Amsoil PI. It almost feels like when you take a small 1 cyl engine and ground it to shut it off, then quickly remove the ground just before it cuts out, only a very very fast hesitation or bog. The engine doesn't stall out, and if you hit the gas during this bogging it has tons of power! There is an occasional tiny miss at idle, compression is strong and in spec, the engine has just under 70,000 miles on it.
I am 100% certain there are on vacuum leaks.
The truck has plenty of power. I'm thinking plugs wires cap rotor? I will probably replace if you guys think its a good idea, but they don't have much miles on them, fuel pressure is spot on, filter is new.
Suggestions?
TIA
Frank D
As always thanks.
Suggestions?
TIA
Frank D
