Originally Posted By: punisher
Simple stuff first.
The idle trims you posted- they are at idle? Have you screwed with the base idle?
If your idle trims are Ok at idle, you can rule out vac leaks (lean) or MAF (rich at idle).
My advice- verify base idle with IAC disconnected. (engine at op temp etc) After that, disconnect battery/clear PCM memory and reset idle strategy.
Yes, the trims are idle, with A/C off. Base idle screw hasn't been touched since it left the factory. Disconnected the IAC, and the engine ticks over at about 500RPM. I've disconnected the battery and cleared the PCM memory several times over the course of troubleshooting it.
This afternoon, I pulled the the connectors off the PCM, the body harness where it joins the engine harness, and the TPS sensor and hit all of them with LPS NoFlash electrical contact cleaner. We'll see if that makes any difference.
Simple stuff first.
