There are some interesting nuggets in this catalogue that need to be discussed on other threads:
1. In pages 9-10 (the numbered pages on the document, not the PDF pages), the 15W-40, 10W-30, and 0W-30 diesel motor oils that meet API CH-4 or CI-4 all have a stern warning: "Do not use in gasoline engines equipped with catalysts." The 15W-40 and 0W-30 are nonetheless listed as meeting API SL, which was just obsoleted for gasoline engines by SM. Some BITOG threads months back noted that a number of motor oils for diesel engines were appearing with no API Sx rating or actually said not to use in gasoline engines. The catalyst warning here is the first time I've seen a reason. So what is in the diesel oils that kills catalysts, phosphorus, perhaps?
The straight SAE 30 shown on page 11 has no such warning against use in gasoline engines, but it meets CF/CF-2 instead of the newer CI spec and lists no Sx spec.
2. On page 26 and again in a note with a chart on pp. 71-72, Ford explicitly says not to use anything but the original green antifreeze on vehicles made before 1999. The longer-life yellow (Premium Gold) and the Dex-Cool compatible orange (Specialty Orange) are not to be used in these older vehicles. Ford also says not to use the orange (Dex-Cool) in any vehicle but the two specific models listed. Some BITOG threads have discussed switching to longer-life coolants or Dex-Cool in older vehicles, and the consensus seemed to be that there would be no harm. So why would Ford have these stipulations?
Now for what I suspect is a boo-boo: on page 66 the automatic transmission fluid chart shows the venerable C-6 using Mercon all the way back to 1977, the first year of the chart. I seem to recall that the C-6 used Type F until roughly 1985. The pages discussing these fluids warn not to use any Mercon fluid in a transmission that used Type F, so this isn't a case of allowing a retrofit.
Comments?
Oh, and why did Ford set up the PDF to jump from page 92 to page 151? What would be on the missing pages in the printed catalogue?
