I found the specs for the bearing clearance of the 4.6 although I don't know nor do I think it includes all years . I believe the earlier engines had a bit more clearance .
These buddies are built on the low side to say the least and while there look at the rod side clearance ! That increases oil pressure as well or could be looked at as does not bleed oil pressure needlessly . The rod bearing clearance is almost ..... normal------ for the hi-rpm in you
When they lowered the clearances they kicked up the oil pressure for the light wt oil . 100lbs at cold idle
Go ahead and run a dino 40wt in this one when cold...I dare you
I think I told the forum of a cam sticking to the head in one of these with a high 30wt when really cold, if not ,I just did
http://www.mach1registry.com/Specs/Specs.htm
[ May 29, 2004, 07:29 PM: Message edited by: Motorbike ]
