Have torn apart a 1993 ford explorer engine 4.0. Only cylinder 5 is carboned up. Hard carbon about .5 inch thick by valve seats on the head. rest of cylinders are cleaned and good.
General symptoms before taking apart were: misfiring, low gas mileage, spark plug fould, no codes, good compression. lots of oil by valves
MIleage on engine unknown becaseu it is not orig. This could be a new year engine and one source said that a new engine in a 93 could cause problems.
mechanic diagnosed as cracked ring but cylinder walls look good. Is it possible the rings are stuck? and how would we know. top of piston looks silver like it is brand new, other pistons have normal wear.
Are there any know problems with this engine? Have a chance to buy a used engine with 71,000 miles for $550. What are the options you would suggest.
