Hi guys,
Both my parents' 2006 Ford Freestar 4.2 V6 and 2007 Ford Ranger 3.0 V6 2WD are close to hitting 100,000km and I will be doing a complete servicing for them. I couldn't find any service manuals for these vehicles as easily as I could with the Japanese vehicles I've owned. For the most part, this should be basic service using the recommended fluids and parts...but I thought I would ask just incase you guys might see any roadblocks or small things that I may have overlooked.
The procedures I will be performing:
1. Oil + Filter change. Pretty straightforward, I already do this every 10,000km for them using Quaker State filters + Motomaster Formula 1 full synthetic. Might switch to shorter 8,000km OCI for better peace of mind, using Purolator filters now that Walmart carries them.
2. Automatic transmission fluid drain. I was just going to do a drain and fill, but it looks like these vehicles might have a filter that I have to drop out and replace. Hopefully the transmission pan is easy to drop. I would use a liquid type gasket to seal up the pan again. Or should I be using the fiber gaskets?
3. Spark plugs. Although I could probably push the change to 150,000km I figure I would just change these mostly to avoid them welding into the aluminum block over time. Should be pretty straightforward I hope?
4. Clean throttle body, MAF, + air filter check. Pretty straightforward unless you guys see anything tricky on the 4.2L and 3.0L engine.
5. Power steering flush. Standard stuff.
6. Brake flush. I normally go with a DOT 4 fluid.
7. Fuel filter change. I hate changing fuel filters. I am guessing the Ranger has it under the chassis frame somewhere. Not sure where the Freestar has its filter, but I was just going to follow the fuel line. Ford seems to use a clamp type connection on its filters, versus the screw on flare type that the Japanese use. I actually prefer this since there's less chance of stripping threads and I always seem to get a leak the first time I tighten the flare type fittings.
8. Differential flush (Ranger only, 2WD). Seems pretty straightforward, but it looks like I have to remove the differential housing, clean the internals, and apply a liquid gasket on the edges before sealing up the differential. I will also check the differential breather. liquid vs fibre gasket? Like with the transmission pan, I think I would like to stick with a liquid gasket since they seem to seal better, but correct me if I'm wrong.
9. Drain and fill coolant. Pretty straightforward.
10. Other miscellaneous things. It appears the driveline on the Ranger uses sealed type joints that don't have grease zerks, so I will just leave that alone. I am also unsure if the bearings or axles require additional lubrication. I was just going to inspect these and leave them be if nothing is wrong. I would also be inspecting my front end components (ball joints, tie rod).
So that's my plan. If you guys see anything that I've missed or have any comments in regards to my servicing plan, let me know!
