Is this even possible? I found a couple guides on some Android forums on how to do it but my phone doesn't seem to have the same menu options as those.
The router that we got from our ISP (Sparklight) broadcasts the same network on both 2.4 and 5 ghz.
Because of this, my phone (Moto G Stylus) is CONSTANTLY flipping back and forth from the 2.4 and 5 ghz version of our wifi.
It's bad enough that I had to disable wifi calling because when I'm on the phone and my phone would switch from 2.4 to 5 ghz or vise versa the call would drop almost every time.
I've also had a real bad problem with my phone deciding to flip from 2.4 to 5 ghz (or the other way around) while I'm in the middle of loading a page and then it won't load because the network changed.
I do have unlimited data and I would use it, but, I live in a rural-ish area and inside the house I'm usually stuck on 3G or 1X.
The only solution I can think of right now is to just buy a 2nd router, plug it into the already existing router, and broadcast my own SSID just to use my phone on.
I cannot be the only one who has had this issue...
