Originally Posted by Mad_Hatter
Originally Posted by ZeeOSix
You think Blackstone has ever correlated "Insoluble %" data to particle count data on the same UOAs to see how they compare? I have from UOAs posted on this site, and I see no real correlation at all between the two.
Dunno, that's a great question for Blackstone (or any test facility for that matter). The results of a particle count and insolubles test can only correlate if the test method is the same.
That said, the insolubles value is a composite parameter (includes particles, contaminants and degradation products that are dissolved or dispersed in the oil) that reflects the degree of oil degradation and oil contamination and significant levels can be a sign of several things occuring including insufficient oil filtration.
Unless I'm missing something (my understanding of "insolubles") if my UOA showed a low insolubles value I wouldn't be worried all that much about particle count or the efficiency of oil filtration system.
I would hope that if Blackstone saw a high insolubles value that they would recommend additional testing for particle count/fuel dilution to get better visibility into that number and determine what's causing it to be so high (fuel contamination, soot, blow by problems, additive issues, oil oxidation etc.) since a high insolubles level is very detrimental to oil integrity (wear, deposit/sludge formation, thickening of the oil etc).
I'd like to know what size range of particulate the "insolubles %" number is measuring. I would think it's particles that are larger than than what most decent oil filters would trap (larger than 20~40 microns). If that's the case, then it only makes sense that a higher efficiency oil filter would lower the insolubles measurement. But as my UOA data comparison shows, the insolubles number does not correlate with the particle count data.
You can have two different tests and methods associated with those tests, and if there's a correlation then you'll see it. A good correlation between insolubles % numbers and PC numbers would show that as the PC counts go up (ie, dirtier oil) then the insolubles % number would also go up. But the data doesn't show that as I showed with examples in that thread I link to a few posts ago. That's why I think the insolubles % number on UOAs really doesn't reflect the true cleanliness of the oil or the filtering performance of the oil filter.
