I posted this to terrylove.com, but so far no response and BITOGers are always so helpful, so here it goes.
The tub is draining a bit slow, so I decided to remove the stopper and thought it would be very easy. Turns out, not so easy.
-No set screw.
-I have tried to turn the stopper CCW when there is tension, but it is not coming off.
-After removing the top, it looked like the stopper was turnable via a screwdriver in the top, but no joy.
-I put needle-nose pliers on the brass section and it turned, but it never loosened that I could turn it by hand, so I stopped.
Not sure what brand of stopper/drain, but the home was built by Lennar in 2013 (if that matters).
I purchased a drain weasel at Home Depot and it cleared the drain, but I still want to get the dang stopper off.
Any ideas and thanks in advance.
-No set screw.
