It's been awhile since I've messed with quick disconnect connects for relays and such. I prefer and LOVE the butt splices that are made of heat shrink vs. nylon. I use the full Stakon system where you crimp and heat shrink. As you do, a dab of solder in the butt splice melts as well which kinda solidifies the joint.
I'm not so sure about these pesky disconnect though. Traditional nitrile ones have the full boot over them. The disconnects have like a plastic head with the heat shrink tube over the metal crimp portion. However when you crimp, the heatshrink tube tends to move a bit...
For those familiar with the onese I'm describing, love to hear your thoughts.
Seems to be a more cleaner setup with the nitrile disconnects and then just corresponding heatshrink where the wire meets the connector.
I tend to get real detailed and *meticulous* when it comes down to any wiring......this has carried over from anything in the home or at work --- fiber optic cables---you should see my home alarm panel ;-)
