Originally Posted By: ram_man
I changed the oil 600 miles ago to Mobil 1 ep 5w20 and in 600 miles it's dropped half a quart. I thought maybe the timing cover was leaking again since it was recently replaced but nope. Nothing is leaking anywhere.i know it's said on here switching brands sometimes the engine will use the new oil for a little while. But half a quart in 600 miles seems excessive. When I ran vwb it didn't drop at all in 4000 miles. So what gives?
My 2014 Ford Focus used oil for the first 17,000 miles, and early on it was about as bad as yours sounds. It stopped using oil when I stopped using MC 5w-20 semi-synthetic and went to 5w-30 whatever brand. Not a drop went missing from there to 36k when I traded it.
Had the same issue with 2011 Ford Fiesta, only it didn't last as long, car used oil for about 10k, MC 5w-20, swapped it to Supertech 5w-20 and it was worse, finally threw whatever 5w-30 I had laying around at it and oil usage stopped. Nary a clue as to why on either car. No drips or drabs anywhere that I could ever see.
