Ford C4, type F.
I stuck a plastic hose on the cooler line and ran it into a bucket with liter markings.
Started the car, and it pumped about 2 liters out before air came up. Refilled the 2 liters. Repeat process. Run it through the gears. I used 8 liters.
I initially ran a hose into a fitting on the cooler to top off but discovered that gravity feed won't work very well. It would seem the fluid must be "pushed" through the cooler.
