Originally Posted By: Sam_Julier
I use Mobil 3309 in 4 V70 wagons. Cooler line exchange every 20k, drain and fill every 10k. They shift like butter. Amazon delivers Mobil 3309 for $6/qt, RMEuropean in Colorado delivers Aisin 3309 for $5.85/qt and the Pennzoil High Mileage Full Syn ATF with JWS 3309 approval (not recommendation) is $5.75/qt at PepBoys. I also run a Dimple Magnetic drain plug which always has black metallic sluge at each drain. I have no idea if the Dimple Magnet helps.
As a note I recently changed the 1993 245 over to the Pennzoil Full Syn mentioned above. The 2-3 and 3-4 shifts are now imperceptible and the initial shudder at start up is gone.
Actual name is Pennzoil Multi Vehicles Full Synthetic ATF.
There is Pennzoil High Mileage ATF, but this isn't recommended for JWS 3309.
